![]() | Home > Technical (L322) > Slight play in steering ?? |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Have a look at the universal joint the connects the steering shaft to the rack, there's a nut that holds the joint onto the spline which can become ever so slightly loose and causes the steering play. Tighten up the nut and you should be sorted.
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 ![]() ![]() ![]() |
Hey
The section of steering column between the rack and the bulkhead can be replaced easily without having to touch the steering column inside the car. Replacement shafts aren't that expensive either, I got my column shaft and rack replaced on my old TD6 a few years ago and it wasn't expensive then. Think I still have the old shaft in the garage somewhere as it wasn't in too bad a condition. |
Thanks
Dug out my old column and have made a couple of notes to show where the top of the column is located in the engine bay.
OMG ! - Thank you very much
So luckily enough I was able to get a second hand lower steering shaft for £20. At my local breakers that had an L322 with an engine out so it was easy enough to remove.
There is a cap and a piece on the rack that will only allow the shaft to fit one way onto the splines, as seen in the photo.
Ive swapped over the steering wheel before so thats no mean feat. interesting you mention about the steering angle sensor as I saw there new guy plugging in a snap on reader as I was comming back, I did ask why and he mentioned the steering angle sensor too.I only get that when I disconnect the battery and just do a steering lock to lock to reset it and re enable the air suspension.
It sounds as if he has reset / recalibrated the steering angle sensor. If the vehicle is driving true, I would be inclined to 'centre' the steering wheel rather than do the tracking, as that would throw the steering angle sensor off by 10 or so degrees.
So I ended up removing the steering wheel as you suggested and shifted it to the right by one spline. I
