Home > In Car Electronics (L322) > Voice command.
tommo10ferrets
England 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Voice command.
Morning all, have just changed ( literally 10 mins ago} my bluetooth module from a gen 3 to a gen 9, the gen 3 worked fine, voice etc, only it wouldn't download the contacts to the phone book, so bought a gen9, plugged it in, all fine, down loaded the phone book, made a couple of calls, all ok, then i tried the voice button, all it done was to ring the last number, would anyone know way this has happened? worked great on the old unit, could the gen 9 unit be faulty? both units have "Mit Ses"
Regards
Tommo
Post #571703 3rd Nov 2020 11:46am
Weegie
Ringing the last number is the standard for a single press on the telephone button. John
GAP iiD BT
Post #571729 3rd Nov 2020 3:28pm
mjdronfield
Someone posted a similar issue recently, and I made the mistake of replying as above..... he means the voice button, not the phone button. So something strange may be going on.
Could always swap it back to prove a point.
Let me see if I can find the thread.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #571731 3rd Nov 2020 3:39pm
mjdronfield
Ok, I must now admit that that might have been on the Facebook group and not on here.... oops.
I take it you don’t have a voice module there already? Though that would have also affected your older ULF. I thought that MIT SES did not appear till Gen 6, but I’m old so have an iffy memory.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #571733 3rd Nov 2020 3:48pm
tommo10ferrets
Update
Evening all, I plugged in the Navcoder & scanned the Ulf module, in the dialogue box it said unidentified module (or words to that affect) so scrolled down the available units & found Ulf, filled in the boxes, enabled voice & coded. My phone contacts were visible on the dash ( scrolled through them, all there), so tried the voice button to dial a name, after I said the command (dial name) it said " No phonebook" It's clearly there, so I manually entered a few names/numbers, then tried the "Dial Name" command, it worked. Now I was under the impression that when the phonebook is downloaded to the car from a phone, that the numbers/names would automatically be available by using the voice button ? is this not the case? is the technology too old? Forgot to add in the first post this morning that I also had to manually enter the names in the gen3 to get the voice command to work, at that time the gen3 never downloaded my phone book, hence changed to this gen9. thanks for your replies, it's appreciated, any thoughts will be welcome.
Regards
Tommo
Post #571776 3rd Nov 2020 8:59pm
mjdronfield
I don’t believe it works like that. Voice command is a separate function really. Your phone book is only on the screen and the cluster for you to scroll through.
Numbers and names to dial via voice have to be set up separately, as you have found. Was the same when I put a ULF into my TD6.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #571779 3rd Nov 2020 9:07pm
mjdronfield
Here’s the BMW ULF manual, if you don’t have it.
https://www.fullfatrr.com/gallery/albums/u...Manual.pdf
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #571780 3rd Nov 2020 9:10pm
mjdronfield
I have a separate voice and phone button on my 2011 so I might be having a blonde moment 🤣 looks like the voice button on is supposed to redial the last number called.... need a longer press to use voice....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #571781 3rd Nov 2020 9:19pm
tommo10ferrets
Hello, Thanks for the manual MJ, very informative, so it looks like all's fine, I'll input the rest tomorrow, I have got the pairing connections running from the back to the front of the car, its coiled up inside the rear access panel, my bottle went when I tried to remove the pillar trim between the front & rear doors to run the cable in, tried pulling it off but its tight & i didn't want to break it, I just throw the cable & switch over to the front seat & pair from there, beats connecting at the 54pin plug & then running round to the front to get in the car & turn the ignition key. will have to bite the bullet I think, I just need to work out where to put it, got to cut a 19mm hole for the switch to come through, somewhere near the power socket I think, if there is enough room inside the plastic panel that is, switch is about 15mm deep, bought 5 of them from Amazon, the type that make connection when button pushed in, broke connection when let go, so ideal. Thanks for info & suggestions.
Regards
Tommo
Post #571790 3rd Nov 2020 10:16pm
mjdronfield
I never fitted a switch in the front, as I figured you only need to use it when you get a new phone, plus you can also put it into pairing mode with Navcoder.
When I got mine working, I just wired a little push switch in the left compartment of the boot, happy to dash to the front to work the ignition.
Could you put something in the ash tray? I know that pops out so would be easy to work on.... or even underneath the ash tray insert, so it’s hidden till you need it? Guess you could get an ash tray insert from a breakers to hack about, and keep your one if you want to put it back standard.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #571793 3rd Nov 2020 10:38pm
tommo10ferrets
Worth having a look, I'm off work Thursday & Friday (well at the moment I am) so I'll probably have a look then.
Regards
Tommo
Post #571794 3rd Nov 2020 10:42pm
