Home > Maintenance & Mods (L322) > Front and rear brake pads and discs
Page 3 of 3 <123
Billie
England 2006 Range Rover Vogue 4.2 SC V8 Buckingham Blue
Ouch
What about the time needed to replace all four discs and pads? My garage has quoted 4 hours (£220 + VAT) - is that fair?
Just come back from my garage, 8 hours and £1929.98.
4 X Pir Scveras, discs all round, pads all round, handbrake shoes, 2 X calipers, wheel balance, 2 x sensor, fluid change.
VAT is the killer.
Post #570684 22nd Oct 2020 6:31pm
ur20v
A Trap
Deleted
Post #570722 23rd Oct 2020 11:34am
6029 king Stephen
United Kingdom 2008 Range Rover Vogue SE TDV8 Rimini Red
In the end, the garage charged me £220+VAT for changing the four discs and sets of pads but did not fit the Caliper I provided or the pad wear sensors. They also charged me 0.6 of an hour to check the rh rear Caliper as the slider had seized. The total bill was £309.60 including £5 sundries (copper grease). The total for all the parts was around £260, so for me the killer is the labour charge. I had seen a video on YouTube on how to do it but I don’t possess a car jack or axle stands etc and as it is the brakes, feel better if a competent person undertakes that kind of job. Sadly, I had to replace all four tyres during October as all had perished/low tread depth. I chose Pirelli Scorpion Zero tyres at £192 each (£768) so it has been an expensive month...!
Post #571454 31st Oct 2020 11:26pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Don’t you have the vehicle jack? What are you going to do when you have a flat tyre and need to put the spare wheel on?
Bit odd to put new pads and discs on but no sensors and refit a seized calliper.
And on a different note Brenda. Constantine, fitting non manufacturer/dealer pads and discs does not class as a modification. Don’t be daft and don’t spread fake news.
Post #571461 1st Nov 2020 6:16am
Brian Considine
Bl4ckDOg.
If you want to have a "pop" at me that's fine - I can take it.
I expressed an opinion - people are free to make up their own minds.
However, please extend the courtesy of quoting my actual name & not a made up bastardised version - at least I have the required spheroids & don't hide behind a handle.
Have a pleasant rest of the weekend & enjoy the coming lockdown. 2003 Range Rover Vogue TD6
Post #571468 1st Nov 2020 9:49am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Might have been expensive mate but it was the safest option by sounds of it for you. Nothing wrong with opnely admitting that you'd need to watch you tube on how to do the brakes and you don't have the suitable tools so best to be safe n get someone else to do it mate. Braking area is not something you wanna be doing if your not certain on it all
Post #571472 1st Nov 2020 11:05am
6029 king Stephen
Yes I do have the jack but wouldn’t trust that to remain stable enough whilst removing brake discs without the benefit of axle stands. In my opinion, kit should only be used for what it is intended for - the jack is for lifting one part of the vehicle to facilitate the changing of a wheel. I would need a trolley jack and axle stands before contemplating doing any maintenance work where the wheels need removing.
Post #571558 2nd Nov 2020 10:06am
Here here Mr King, couldn’t agree with you more sir...
Post #571560 2nd Nov 2020 10:39am
Brianx2t
United Kingdom 2006 Range Rover Vogue 4.4 V8 Java Black
What was the final consensus on this? I have a seized rear calliper (single pot) and utterly pitted disks so my plan is to replace the entire back-end gubbage. I have the 4.4 petrol on an '06 plate (the awkward BMW crossover year) and there appear to be various FF 'standards'. Is there an easy way to determine what parts to order? I'll be looking for new callipers, pads and disks but is there anything else I should replace?
I don't want to go daft on costs, but neither do I want poor quality parts. Any advice is appreciated.
Post #601848 26th Jul 2021 11:46am
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Re: Ouch
VAT is the killer.
Billie, whereabouts are you inSW (no need to be shy).
If you can, go to T&S Norman just south of Shepton mallet. there is no better and he won't rip you off!
Post #601859 26th Jul 2021 12:51pm
Page 3 of 3 <123
