![]() | Home > Technical (L322) > Engine System Fault |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Could be the supercharger cooling pump not operating in the correct rotational direction. A search will reveal how to check the wiring. Previous cars:
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
Not the supercharger pump in this case, his runs on the devil's brew |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
steve, can you update your car profile please..... ... - .- -.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Codes need reading....if you don't have one take it to Martin Hind at Dartford Transmissions and Autocare. LR guru and enthusiast to boot |
It was the profile that did for me. My bad, should have read the post more carefully 🤔. Previous cars:
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
I'm guessing the car needs a little more breath pulling up those hills [know them well from my days in haulage] & when she gasps and there's a split in one of the four donut hoses, that'll give you that message.
6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101 ![]() ![]() ![]() |
Took the car to local garage to have fault codes read and they suggested it is likely to be EGR fault. I wasn’t sure if the EGRs had been changed when I bought the car so I had these added to the warranty. I went to an Indy just after purchase and told me after a visual inspection that it looked like the EGRs had been changed as they looked very shiny. The car is booked in for a diagnostic inspection next Wednesday so I should find out then what is wrong.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
Hi Steve, make sure you check the turbo hoses thoroughly, especially the one on the right as you look at the engine, they must be removed as they split under the webbing and cannot be seen in situ. Simple to take off, just a jubilee clip, then give them a good squeeze and you’ll see the splits if there. Went twice on mine in 5 years. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
^wot he said, top right inter cooler hose needs taking off and thoroughly checking for splits.
And the winner is.....
Quelle surprise! Warranty Wise (endorsed by Quentin Wilson) has declined my claim for the repair because the inlet manifold is not included or covered on my plan (Silver)! The warranty was provided by the dealer who sold me the vehicle and cost him over £1,000. I have looked at my plan and the Gold and Platinum ones above it and none of them mention the inlet manifold or any part of the exhaust system. My plan covers the engine’s moving parts, strangely including the engine block (is that a moving part? I know it moves when the car moves but hadn’t considered it a moving part of the engine). I had specifically asked for EGRs to be added to the plan but didn’t realise I should have asked for every other component not mentioned to be added.....!
My Pax side inlet manifold was replaced ay a cost of £1600 (inc. labour and VAT). Apparently the injector loom needs replacing as it all comes out. |
I have discovered this weekend that if you set cruise to 70mph the car will go up hills and along the flat areas without any engine system fault coming up. Only if you try to power up hills does the message appear. It might also appear when towing something up hill (I haven’t towed anything yet so can’t confirm this). If you are replacing the inlet manifold you also need to buy two EGR gaskets (£25! From Land Rover) as well. Car is due in at garage on Monday late afternoon and should be ready on Tuesday or Wednesday. |
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 ![]() ![]() ![]() |
Be careful driving it until it's sorted - i've read theories about this sort of leak causing turbo overspeeds and ultimately leading to their much more expensive demise.
