Home > General > Looking to buy |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4309 |
All track 4x4 in Malvern.
1st Nov 2020 5:57pm |
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 |
Thanks for response Dr Rob. Is blanking the EGR to stop the water/oil ingress I've read about or something else. Are there any implications in just blanking them off? |
1st Nov 2020 6:11pm |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 405 |
Are you looking at the Sport or the L322 FF?
1st Nov 2020 6:21pm |
Hi Tommy, no it's not a sport it's a ff Range Rover. I thought the Sport is the one you need the body off to get at the turbo, is the Ff one the same? Is £3,500 a realistic replacement figure? |
1st Nov 2020 7:02pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8662 |
Sport has a separate chassis and the body can come off leaving a rolling chassis to work on with better access.
1st Nov 2020 7:56pm |
Thanks for info, going for inspection and test drive tomorrow so will see how it performs. |
1st Nov 2020 8:18pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7831 |
If it’s exactly what you are after, and all’s well, could be the car of your dreams.
1st Nov 2020 9:02pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
+1 forget the 3.6 - just go for the 4.4 - more power, more economy, better dash, plus it’s got a far better 8 speed gearbox and even though you may pay a little more - it is always still worth more 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
1st Nov 2020 9:59pm |
Thanks, can't see a 4.4 with reasonable mileage that I want to go to in money terms. This one has the digital dash etc, will see how it drives but will have another look at the 4.4, I understand it does have advantages over the 3.6. |
1st Nov 2020 10:08pm |
Like none of the turbo issues..... without the other advantages.
1st Nov 2020 11:13pm |
Worry I can do without but I guess any car, I have a Jag and TVR, will always cause bit of anxiety🤣😂 |
2nd Nov 2020 12:10am |
Generally, if a turbo goes on a 3.6, mostly without warning, it takes the engine with it. The biggest issue on the 4.4 is the oil cooler leaking.
2nd Nov 2020 9:21am |
Yes I see the 4.4 is the better option all round. Will have a look round and see if I can locate one. |
2nd Nov 2020 9:42am |
I had the secondary turbo on my 4.4 replaced as it was leaking oil. No engine is infallible. Proven service history, receipts, current condition are all important but 100% be prepared to spend and have a contingency fund.
2nd Nov 2020 9:52am |
