Home > Technical (L405) > Door Lock Actuator Removal
zoso
Scotland 2013 Range Rover Autobiography SDV8 Santorini Black
Hello All
It would appear I have the well known lock actuator motor fault - front passenger door won't open from the inside or outside and the orange light on the armrest is lit all the time. Looks fiddly to replace the actuator but I'm going to have a go at it the next dry day we get. My question is........how do I open the locked door to remove the door card/actuator ?
thanks. 2017 4.4 TDV8 Autobiography
2016 4.4 TDV8 Autobiography - GONE
2013 4.4 TDV8 Autobiography - GONE
2010 3.6 TDV8 - GONE
2008 3.6 TDV8 - GONE
2002 3.0 TD6 - GONE
2006 Discovery 3 TDV6 S - GONE
2006 Discovery 3 TDV6 - GONE
2003 Discovery 2 TD5 - GONE
1999 Discovery 300 TDI - GONE
1998 Range Rover DSE - GONE
1997 Discovery 300 TDI - GONE
Post #571224 29th Oct 2020 9:20am
doesnt the front passenger door have the manual 'key' lock .. ... - .- -.
Post #571227 29th Oct 2020 9:40am
zoso
Hi Stan
I'll need to check thoroughly - it was a bit dark last night. The drivers door latch has a hole on the underside to insert the key and prise open the cover but i couldn't feel one on the passenger side Shocked 2017 4.4 TDV8 Autobiography
2002 3.0 TD6 - GONE
Post #571230 29th Oct 2020 10:09am
i've just had a look at mine and you are correct , its the drivers door on the L405...i think its the passenger door on the L322..
have a look in the WM or do a search..
this is for the L322 but might help ..
https://www.fullfatrr.com/forum/post328029.html#328029 ... - .- -.
Post #571231 29th Oct 2020 10:21am
zoso
Thanks Stan. I'll have a trawl around and see if there is a way to open it. I'm sure if I took it to a Land Rover dealer (last resort) they could have it open without resorting to coat hangers.........or maybe not Confused 2017 4.4 TDV8 Autobiography
2002 3.0 TD6 - GONE
Post #571243 29th Oct 2020 11:49am
