Home > Technical (L322) > 10-12 deployable sidesteps wiring loom
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Finally managed to source a set of steps. Came with 2007 wiring loom.
I already have 10-12 ECU. (I haven’t checked if plugs are same yet)
Anyone know the difference between 07 and 10-12 wiring looms?
Post #571000 26th Oct 2020 4:10pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Not completely sure -- the 2010-2012 fitting instructions PDF is in the wiki under the 'Body' section. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #571005 26th Oct 2020 5:53pm
JNC
The instructions that have information for both models only shows a few extra wires at the button.
But the instructions that are solely for 10-12 show a few more connections at the Fusebox too.
Post #571009 26th Oct 2020 6:19pm
Bushy30
Having only fitted a set to a 2011, I suspect you'll struggle without the correct wiring harness. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #571023 26th Oct 2020 8:04pm
JNC
It seems the diagrams are different. However using the 07 loom and 10-12 ecu I have got it to work.
Just connected as per the dual instructions. I don't know what the extra connections at the top are for. I don't have the switch as yet anyway.
But works normal otherwise.
Post #571024 26th Oct 2020 8:06pm
Bushy30
The switch is important -- enables you to enable and disable steps -- locked in, or out. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #571073 27th Oct 2020 2:11pm
JNC
Turns out there was a switch in the bundle of parts. I had ordered one.
All fitted and working as expected.
Post #571106 27th Oct 2020 10:40pm
Andy
I bought the loom and ECU in anticipation of getting the steps from John Craddock. After three months waiting they said they couldn’t get them anymore.
So I’m still looking for steps if anyone knows to a set. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #571326 30th Oct 2020 3:28pm
JNC
During my search I found another set for sale. They wanted £350. I can get contact details if interested.
Post #571329 30th Oct 2020 4:10pm
