Home > Maintenance & Mods (L322) > anoying drip
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
anoying drip
recently I had a major fuel leak from the high pressure rail on top of the engine (TD6) which is now fixed and the car is once again running well, however I have noticed that there is what smells like fuel dripping from the under tray intermittently.
So question is this an accumulation of spilt fuel from the leak finally escaping?
or is there something towards the front of the engine that can leak without effecting the overall running?
I've removed the top covers off the engine and from what I can see everywhere appears to be dry and thankfully the fuel gauge is not dropping like a stone, so am a bit of a loss
over to you for ideas......
Post #571004 26th Oct 2020 4:23pm
The air con ?
(are you sure it is fuel and not water) .
Post #571030 26th Oct 2020 8:31pm
Discofish
Hi Joe thanks for the reply, to be honest I don't know I can smell fuel inside the car (but that's because the fans are on I guess) and outside standing next to it so that's what making me think it is fuel. problem is it's not stopped raining so is all the surface water getting splashed up and picking up the spilt fuel after my leak?
I guess all I really need to know is there a leaking pipe/cooler etc. etc. somewhere that's going to fail big time somewhere totally remote, if it ever stops raining I'll have to remove the under tray and check/clean.
Cheers
Post #571051 27th Oct 2020 8:44am
The air con drain is by the gearbox, so no covers need removing to see that drip... .
Post #571059 27th Oct 2020 9:15am
