Home > Technical (L322) > Oil in plug on actuator
Kedgers
United Kingdom 2016 Range Rover Vogue SDV8 Santorini Black
Hi there
Im new to this site but Ive had my RR Vogue since 2016
Its not under warranty
Been having a real saga as it showed yellow engine warning light and went to limp mode.
I took it to the independent guy I use and he said there had been an oil leak which filled the plug on the actuator on the turbo.
Basically the oil has followed the current in the electrics?
He sent the actuator away for repair and cleaned it up but says the fault hasnt gone away.
Apparently Land rover themselves dont do any repair or replacement to the actuator and would just change the turbo at huge expense to me.
Ive now been told this should be a recall issue with foc repair to me but Land Rover aren’t acknowledging that and say I need to book it to a maindealer.
I have explained to Lookers and they say they arent aware of any recall for this and want big bucks just to do diagnosis.
Anyone know anything that can help please?
thanks Rob
Post #570666 22nd Oct 2020 3:43pm
Mikey
Actuator is available as a separate part, £465 + VAT, last time I had to replace one Thumbs Up
Post #570707 23rd Oct 2020 6:01am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi
Are you using a Land Rover indy or a garage that works on anything with the occasional Land Rover/ Range Rover coming in?
Jim
Post #570708 23rd Oct 2020 6:21am
Kedgers
Thanks for getting back to me guys.
So its good to know you can buy the actuator as he told me if it went would need whole new turbo.
Do you have a link to that or can you let me know where you purchased the actuator from please?
Thankfully it hasnt actually failed ...it just filled up with oil due to the leak that had come down the wire
(apparently!)
As to my indie guy, he is Land Rover specialist.
so as it stands, all is working but the actuator plug will be slowly filling back up with oil & a matter of time
before I get the yellow emissions light & limp mode again.
many thanks
Kedgers
Post #570735 23rd Oct 2020 1:38pm
Baltic Blue
I am not an L405 expert, but I know their is a thread on here detailing a service bulletin with a mod to the oil level monitoring wiring on 2016 - ish L405’s to prevent the actuator failing because of oil contamination. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #570750 23rd Oct 2020 3:45pm
Mikey
https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf
Post #570825 24th Oct 2020 3:07pm
As Mikey has posted above it is a LR recall.
I had my wiring amended FOC at our local LR garage. Not sure what the result would be regarding a knock on failure of the actuator. But LR are definitely aware of the design fault in the oil level sensor wiring and are replacing that part FOC. There is nothing that can't be fixed with a hammer😜😜
Post #570827 24th Oct 2020 3:20pm
Mikey
Its not a recall, only a TSB, to aid in diagnostics and repairs
If you had it done FOC, you were either under manufacturers warranty, or very lucky Thumbs Up
Post #570953 26th Oct 2020 6:09am
