Home > Technical (L322) > Steering column
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Steering column
Well it have to happens
Some months ago, the solenoid who unlock the steering column didn't opened. I have to remove the fuse 18. Since then it worked normally. Yesterday it happened again twice and I thought that it's solved again. Wrong. Today morning the column didn't unlock again. There is a solution to this without replace the entire steering column?
Post #570713 23rd Oct 2020 8:05am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Have a look for info on the steering lock solenoid magnet, it can be renewed. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #570950 26th Oct 2020 12:15am
A.Pires
Hello Wayneg
Thank you for you answer. Do you know the measures for that magnet, I only found it on the states. It cost 8 USD and the delivery is 65 USD. If I get the measures probably they have it on China.
Cheers
Antonio
Post #571036 26th Oct 2020 10:04pm
wayneg
I think it is 6 x 3 x 3mm but please do your own checking. Saying that I am pretty sure its right. If so get from china.
[url] https://www.aliexpress.com/item/1005001428...QG7j[/url] 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #571042 27th Oct 2020 2:35am
