![]() | Home > Technical (L322) > The dreaded M62 rattle? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I have same engine. Yes to me that does sound like vanos gear rattle. It normally does this when first started, ie cold as, often the non return valves that are easily changeable, allow the oil in the vanos gear to run back, and therefore rattle upon start up. I would research changing the oil maybe one grade thicker at high temp. (That's just my gut feeling)
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 ![]() ![]() ![]() |
Thanks Jon, very informative |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
for the cost of a gasket i'd fit a new one. Otherwise if you put it all back together and it's leaking that's £70 worth of oil you've wasted, because you'll have to drain it again to replace the gasket.
i would get one first, as like above, you could then be waiting for one to come in, should it tear etc. i think you only have o remove the front diff mini-guard and then just unbolt it. (after draining.)
Thanks.
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 ![]() ![]() |
Ebay item
tommo10ferrets Member Since: 29 Apr 2020 Location: leicestershire Posts: 56 ![]() ![]() ![]() |
Morning Matt, I had a very similar noise on my car, changed the lower tensioner & the left bank solenoid valve, noise gone, also change oil for 5w 40, hope this helps.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Not sure how you stumbled across this post but it’s five years old lol Current stable:
Morning Danwilderspin, LOL, I haven't a clue, I was just having a look through the web site, as i haven't really looked through it before & come across it, told my son, he laughed his socks off, I'm putting it down to an age thing, well that's my excuse for it anyway, LOL. but thanks for pointing it out to me, in future I'll make sure the topic is currant !!!!!
Lol good stuff well done catching up with the archive Current stable:
