Home > Technical (L322) > Air Con doesn’t seem to be working again |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 583 |
Just had my ac sorted and although it was a saga the original issue was the compressor - the solenoid as you say. Compressor was actually in v good condition but you cant buy just the solenoid. Obviously mine is a later SC but I doubt the ac would vary between models - its still got to cool the same volume of space inside. Mike - MPx
18th Oct 2020 9:38pm |
HS66 Member Since: 22 Jun 2016 Location: Surrey Posts: 73 |
Oddly the compressors do look different from the pictures I’ve seen between the 3.6 and 4.4 I’m not sure if the SC has a different one too?.
19th Oct 2020 11:22am |
Well I was obviously way off!
19th Oct 2020 12:19pm |
I couldn’t get it on the machine at work today but did put a rudimentary gauge on it from one of the bottles which people have to gas up yourself (I didn’t add any gas at all)
19th Oct 2020 5:33pm |
Plugged in machine again today and it only has about 20g of gas left in it, down from being refilled from 750g a couple of weeks ago.
22nd Oct 2020 12:50pm |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 369 |
Mine had a leak on the high pressure side from where the pipe is fitted to a plastic clip. Best way to find it is to put dye in it and look with a UV light 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
22nd Oct 2020 5:37pm |
Tooltime79 Member Since: 03 Jun 2015 Location: York, North Yorkshire Posts: 27 |
I had a leak in a pipe at the front of the engine which had been rubbing against the earth strap. Have a look at this post:
24th Oct 2020 8:52am |
