Home > Maintenance & Mods (L322) > Head light removal on L322 2012 4.4 td |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35217 |
you can change the xenons without removing the headlights.. ... - .- -.
9th Oct 2020 2:46pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7772 |
From my manual....
9th Oct 2020 3:18pm |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 193 |
Many thanks Stan and PJ for the posts. With my MOT due shortly I checked that all lights were working today. However I took the view that there would not be enough space to withdraw the Xenon unit and bulb. This led to my attempt to remove the whole unit should I need to change bulbs. Great news if the is enough room withdraw them. Youtube covers the sport models which looks to be easy and I didn't fancy taken out the air filter cases.
9th Oct 2020 4:55pm |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 |
So not sure whats in front of them in an L322 from memory but the L405 has an air-box (either side in my car) and you just have 6 screws, then loosen the jubilee clip and it pops out with a bit of mild brute force away from the wing.......deffo a lot easier when I did it this time than squeezing my hand into a ridiculous small space with a HID bulb! all smug in my new plug!
9th Oct 2020 5:20pm |
I’ll take another look tomorrow at the filter areas. as I did think I might just damage a good xenon trying to remove one. Good to be prepared when the time comes.
9th Oct 2020 8:20pm |
This is for the L405.....was super helpful.....
9th Oct 2020 9:47pm |
This one shows taking the airboxes out from the wing better.....didn't think it would be identical for a Sport but it is.
9th Oct 2020 10:19pm |
Well took another look at the L322 light ass'y / Filters. Changing the Xenon bulb looks impossible but Stan is absolutely ring! i imagined a bulb of greater length than it is!! It came and went back in without a problem with careful handling. So its thanks to everyone - knowledge is a wonderful thing.
11th Oct 2020 9:44am |
Add on:
11th Oct 2020 11:06am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2453 |
Easier than removing the bumper to remove the headlight assemblies! |
11th Oct 2020 11:08am |
I think it must be without doubt but will it come straight out or need a twist etc.? Will need to change filters in a month so maybe get a look in at that point.
11th Oct 2020 12:15pm |
the H7 bulbs are held in by a spring type thingy from memory..you dont twist them like the xenons.. ... - .- -.
11th Oct 2020 3:34pm |
Thanks again for your help Stan. I will probably bring forward the filter change which is nearly due and take another look when the cover and pipes are removed. You never know when a bulb will go and who needs a panic when it does. Nice to be prepared.
11th Oct 2020 4:34pm |
On the L405 theres a little "lever" at the side of the bulb and as stan says you dont twist the bulb but you just firmly push the lever tab (clockwise from memory) and they then come out easily. if you don't do the slide of the clip as such then they wont come out.
11th Oct 2020 6:46pm |
