Home > Maintenance & Mods (L322) > TD6 gearbox service
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
TD6 gearbox service
Haven’t had the TD6 gearbox serviced since it was rebuilt about 8 years ago, granted it’s only covered probably 20k miles since then. Is it worth getting the filter and oil changed? If so, where’s best to get the filter, gasket and oil from to do it myself?
Cheers everyone
Post #569314 9th Oct 2020 4:10pm
Fox889
If you fancy the lazy way, pop over to Suffolk Transmissions at Haverhill & see Paul, he did my X5 [same box] a couple of times for me.
If you're doing it yourself, any good 4x4 indy should stock them, Duckworths on this forum is a sponsor so there's a good start. Opie Oils but not sure if they do a filter, should do. Any decent motor factor but check it's the correct spec of oil.
I won't get involved with gearbox oil, too much chance of contamination but any decent BMW Indy can do the job as they're the exact same box as the X5.
Have fun! Smile 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #569348 10th Oct 2020 7:12am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
This is the correct gearbox oil for the GM 5 speed box.
Opie oils sell it for around £70 for 20L
Jim
Post #569352 10th Oct 2020 7:58am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Well worth doing and easy enough as a DIY. I did mine 50000 km after a rebuild and the fluid was no longer clear. By removing the cooler lines you can drain the cooler too or even flush if you are confident and have a willing helper. There is a great video on youtube. Plenty of options on fluid nowadays at least here in Oz I used Penrite Fully Synthetic meeting GM Spec. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #569366 10th Oct 2020 10:25am
Weegie
Would recommend that you get Filtran filter. Original equipment. Don't think the substitutes are reliable. John
GAP iiD BT
Post #569370 10th Oct 2020 11:23am
