Home > Maintenance & Mods (L322) > Iidtool ecu update - anyone had it fail?
Danwilderspin
Mr paranoid here is pretty certain his pcm needs updating and I also have the California stop issue on the gearbox.
I have a monster 110ah battery on my 4.2 recently fitted and a trickle charger.
My worry is if something goes wrong with the update is it bricked!? Does it take long?
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #569069 6th Oct 2020 10:53pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
surely the first step is to back up your current pcm settings?
so you can reload those then go again
blame long covid for me getting the wrong end of the stick. yes I used a ctek 10amp supply
Post #569096 7th Oct 2020 9:33am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
You really ought to have a constant supply on it for any flashing. I have a 10A CTek but I think 25A is recommended. As a fallback some have used jump leads to another vehicle. You can keep the engine running on that one so the alternator does the work. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #569173 7th Oct 2020 9:33pm
Danwilderspin
Thanks I used my trickle charge but tbh I have a 110ah new battery I flashed the air suspension module with a full battery and trickle and it took one minute and all good.
I plucked up the courage to get the pcm one but it’s already on the latest so I just need the transmission which I will do next Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #569270 8th Oct 2020 11:44pm
