![]() | Home > In Car Electronics (L322) > 2004 Audio Upgrade Options - DSP Car |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Android is the way to go -- also use Resler USB connected to CAN and then have Navcoder too -- you'll need an extension loom to run from the new head unit to the BM54 in the back Current: 2011 FFRR Vogue SE 4.4 TDV8
Chaz Member Since: 06 Oct 2020 Location: Oxfordshire Posts: 9 ![]() ![]() ![]() |
Wow, thanks for a quick reply.
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
I changed to a Xtrons android unit in a 2002 Vogue and it's way better than that outdated stock unit.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
You list your FF as 2004. Do you know what Model Year it is? Later 2004 registered FF were MY 2005 which had a much different system. John
It's a 53 plate. Registered 9th Jan 2004.
So one of these would work?
53 plate would be the "older" system. |
Thanks, hopefully simpler? |
There is an ibus app forum, so would probably ask there. When I fitted mine, the app makers were not recommending some Xtrons models.
Thanks for all the input.
So Ive bought a 2nd hand Pioneer AVIC-F88DAB which gives me all the functionality and basic DSP things I need to get good sound. That does mean however that the existing system will largely be bypassed.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 870 ![]() ![]() ![]() |
BMG - there is a second way, especially if your MKIII satnav unit is not working any longer, or you are fed up of the old Land Rover Alpine OEM unit that is now looking a bit outdated after 20 years |
