![]() | Home > Technical (L405) > Help, not unlocking via remote. Cannot switch off alarm . |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
leave it for about half hour then try again..
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2685 ![]() ![]() ![]() |
So managed to start with key held beside steering column. Stopped it and will neither lock nor unlock , I’ll fire in the IID, looks like this is my first issue in 2 years . |
No faults just the Std p040 |
next step would be to replace the battery in the fob..make sure its a duracell, they seem to work best.. ... - .- -.
Lol, done that Stan just back from sainsbury . Sadly no change, battery disco next I think, only thing left .. |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
99% certain that if you disconnect the battery under the boot floor for 2 mins this will re set everything . Running a diagnostic scan probably won't reveal any faults , put the tracker into service mode first ! |
no tracker, well don't think so, away to disco the battery. |
Standard fit one ? , log into your "in control " account and go to vehicle settings / remote / secure tracker . Turn of while you disconnect the battery . |
Car too old for in control. Battery disco worked, have bokked into MD earliest appointment is 2 weeks out so will report back. |
Goodfella Member Since: 04 Jun 2017 Location: Essex Posts: 77 ![]() ![]() ![]() |
WTF is a battery disco? |
Disconnect |
Excellent news that it worked , don't waste your money on taking it anywhere for them to tell you NFF ( no faults found LOL ) |
Airbag light on too, will see what Indy says before cancelling . Just a bit nervous it goes tits up whilst out. |
Ahh the air bag light is on so it definitely needs scanning . Best of luck . |
