![]() | Home > Maintenance & Mods (L322) > Engine System Fault |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6773 ![]() ![]() ![]() |
The body does not need to come off to replace a turbo.
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Also it is possible to sometimes free up the actuators with wd40 or silicone spray and the right hand one is easy enough to get right too to spray and hopefully free up.
I managed to change the O/S actuator arm in situ, it’s a bit of a faff but not impossible. Got - 2017 SDV8 Autobiography in Loire Blue
BlackRider Member Since: 03 Oct 2020 Location: La Manga Posts: 7 ![]() ![]() ![]() |
Hi Kbald,
Hi it's a metal arm you can get too by removing the wheel and wheel liner. The left hand side one is harder to find.
Hey kbald,
Took the car into the Land Rover/Jaguar dealer today and they put it on their diagnostic m/c and confirmed it had low pressure on the r/h turbo and quoted me €2785 to fit a new one! Definitely going to have a go tomorrow. |
What is the error code? It could be a crack in the inlet manifold, which is a common issue. Got - 2017 SDV8 Autobiography in Loire Blue
Alanm3 - they didn’t say what the error code was but they said it was low pressure in the r/h turbo. I have had the r/h wheel off today and checked the actuator which is moving freely, about 20mm up and down so sprayed it with WD40 anyway. Checked the inter cooler hoses and still have ‘Engine System Fault’. |
You can check for manifold leaks by spraying soapy water onto it and wait to see if any bubbles appear, it's quite a well known issue.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Did you remove the Uk passenger side intercooler
Alanm_3 and northernmonkeyjones, I’ve took both inter cooler hoses off which are in very good condition and no splits/holes or soft spots and I sprayed the inlet manifold with soapy water and no bubbles. The car has just over 68000 miles with full main dealer service history so I’m beginning to think that there is a problem with the turbo having gone through the common faults. |
You really need to get the error code(s) to get a more accurate diagnosis.
