Home > Technical (L322) > Rear subframe upgrade
Minilee0
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
I have a 2004 4.4 and been offered a rear subframe complete from a 2011 4.4 tdv8 complete with top and bottom arms basically everything is included, will this fit my 2004 ? Thanks in advance.
Post #568601 2nd Oct 2020 12:29pm
GraemeS
The sub-frame itself has at least different diff mounts so can't be swapped. The knuckles, upper and lower arms have different part numbers but the earlier numbers may supersede to the latest. However if the later ones have larger bushes then the knuckle + arms might be swappable as a set if the inner bushes to the subframe are the same.
Post #568679 2nd Oct 2020 8:10pm
Minilee0
Ok thanks for the input , what I don’t get is the Land Rover parts number for the 2004 and 2011 are the same for the sub frame, the sub frame I’ve been offered comes with everything on it including hubs discs and callipers even air bags
Post #568729 3rd Oct 2020 9:43am
GraemeS
Vin 2A-6A subframe KHE500050, 7A+ KHE500100 according to Microcat 2012. The diff mounts are very different.
Compare how your diff is mounted with the 2011's diff. Sometimes catalogues aren't correct.
Edit: The drawings in Microcat are reversed for the 2 model ranges so appear quite different, but perhaps they are not.
Brit-car list the later one as being superseded by the earlier one which is very unlikely, but possibly the earlier one is superseded by the later one which therefore would fit.
Post #568737 3rd Oct 2020 10:48am
