Evening All, A few weeks ago my car (l322 4.4 petrol, 2003) had a problem with the gearbox, basically in went in to safe mode
no warning from dash, long story short, i changed gearbox fluid, filter, both trans cooler hoses, trans cooler, trans cooler back plate, radiator & carried out the T-stat modification, car was running fine until last Sunday, on my way to fill up i hit the A47, took the car up to 60, went to over take another motor, kicked down, everything fine, then a bong from the dash trans fail prog flashed up then went out, a few seconds later trans message appears again then car bangs into 4th, couldn't move shifter into manual, just stuck in 4th, got the car home ( i had my icarsoft connected & recording, as my son wanted to borrow the car & i was just making sure everything was ok) the code that was thrown up was P0720. I reset the fault codes & took the car out again( recording data, drove about 6 miles) the car performed normally, no problems, after reading up on the Code it looks like the transfer box, so when i got home from work tonight i selected low gear car switched to low, after a few seconds the icon on the dash started to flash, drove backwards & forward a few times & icon stayed solid, then selected high gear, again car switched to high, done this a few times, worked every time. haven't a clue what caused the problem, has anyone any ideas? i'm going to paste the recorded data for the fault & the recorded data from tonight, hopefully some one could shine a light on the data & see something ive missed or if everything is running as it should
Frame 61/154:
Battery Voltage ----- 14.38V
Engine Speed ----- 2400rpm
Engine Temperature ----- 92°C
Gear Ratio ----- 5THGEAR
Gear Selector ----- D
Gearbox Operation ----- NORMAL
Oil Temperature ----- 69°C
Output Speed ----- 2912rpm
Shift Solenoid 1 ----- OFF
Shift Solenoid 2 ----- OFF
Shift Solenoid 3 ----- OFF
System Pressure ----- 17mA
Throttle Valve ----- 36.88%
Torque Converter Clutch ----- PASSIVE
Torque Converter Clutch ----- 5.05%
Turbine Speed ----- 2368rpm
Frame 62/154:
Engine Speed ----- 3072rpm
Gear Ratio ----- 4THGEAR
Output Speed ----- 2976rpm
Throttle Valve ----- 25.24%
Torque Converter Clutch ----- 99%
Turbine Speed ----- 2976rpm
Frame 63/154:
Engine Speed ----- 2752rpm
Gearbox Operation ----- LIMP HOME
Oil Temperature ----- 70°C
Output Speed ----- 2880rpm
System Pressure ----- 255mA
Throttle Valve ----- 12.42%
Turbine Speed ----- 2752rpm
This is the data from this evening
Frame 8/124:
Engine Speed ----- 1472rpm
Engine Temperature ----- 95°C
Front Left Wheel Speed ----- 14km/h
Front Right Wheel Speed ----- 7km/h
Gear Ratio ----- 1M
Kick Down ----- NO
Oil Temperature ----- 78°C
Output Speed ----- 192rpm
Rear Left Wheel Speed ----- 3km/h
Rear Right Wheel Speed ----- 4km/h
Shift Solenoid 1 ----- ON
System Pressure ----- 16mA
Throttle Valve ----- 17.08%
Turbine Speed ----- 896rpm
Frame 9/124:
Battery Voltage ----- 14.06V
Engine Speed ----- 1984rpm
Front Left Wheel Speed ----- 36km/h
Front Right Wheel Speed ----- 19km/h
Gear Ratio ----- 2NDGEAR
Kick Down ----- NO
Output Speed ----- 864rpm
Rear Left Wheel Speed ----- 15km/h
Rear Right Wheel Speed ----- 15km/h
Shift Solenoid 2 ----- ON
Throttle Valve ----- 39.21%
Turbine Speed ----- 1696rpm
Frame 10/124:
Battery Voltage ----- 14.14V
Engine Speed ----- 2624rpm
Engine Temperature ----- 94°C
Front Left Wheel Speed ----- 56km/h
Front Right Wheel Speed ----- 28km/h
Gear Ratio ----- 3RDGEAR
Kick Down ----- NO
Oil Temperature ----- 79°C
Output Speed ----- 1472rpm
Rear Left Wheel Speed ----- 25km/h
Rear Right Wheel Speed ----- 25km/h
System Pressure ----- 167mA
Throttle Valve ----- 42.71%
Turbine Speed ----- 1664rpm
Frame 11/124:
Engine Speed ----- 1280rpm
Front Left Wheel Speed ----- 50km/h
Front Right Wheel Speed ----- 25km/h
Kick Down ----- NO
Output Speed ----- 1696rpm
Rear Left Wheel Speed ----- 28km/h
Rear Right Wheel Speed ----- 28km/h
Throttle Valve ----- 0.39%
Torque Converter Clutch ----- 54.35%
Turbine Speed ----- 1184rpm
Frame 12/124:
Front Left Wheel Speed ----- 52km/h
Front Right Wheel Speed ----- 26km/h
Kick Down ----- NO
Throttle Valve ----- 35.72%
Torque Converter Clutch ----- 47.75%
Turbine Speed ----- 1248rpm
Frame 13/124:
Battery Voltage ----- 14.30V
Engine Speed ----- 736rpm
Engine Temperature ----- 96°C
Front Left Wheel Speed ----- 34km/h
Front Right Wheel Speed ----- 16km/h
Kick Down ----- NO
Oil Temperature ----- 77°C
Output Speed ----- 1568rpm
Rear Left Wheel Speed ----- 26km/h
Rear Right Wheel Speed ----- 26km/h
Throttle Valve ----- 0%
Turbine Speed ----- 1120rpm
Frame 14/124:
Engine Speed ----- 2272rpm
Engine Temperature ----- 97°C
Front Left Wheel Speed ----- 46km/h
Kick Down ----- NO
Output Speed ----- 992rpm
Rear Left Wheel Speed ----- 17km/h
Rear Right Wheel Speed ----- 18km/h
System Pressure ----- 64mA
Throttle Valve ----- 53.96%
Turbine Speed ----- 1440rpm
Frame 15/124:
Battery Voltage ----- 14.22V
Engine Speed ----- 2080rpm
Front Left Wheel Speed ----- 68km/h
Front Right Wheel Speed ----- 34km/h
Kick Down ----- NO
Output Speed ----- 1824rpm
Rear Left Wheel Speed ----- 31km/h
Rear Right Wheel Speed ----- 31km/h
Throttle Valve ----- 30.28%
Torque Converter Clutch ----- 54.74%
Frame 16/124:
Engine Speed ----- 2016rpm
Front Left Wheel Speed ----- 72km/h
Front Right Wheel Speed ----- 37km/h
Kick Down ----- NO
Output Speed ----- 2080rpm
Rear Left Wheel Speed ----- 35km/h
Rear Right Wheel Speed ----- 35km/h
Throttle Valve ----- 45.04%
Torque Converter Clutch ----- 41.54%
Thanks for any information you can supply & or suggestions.
Regards
Tommo
