Home > Technical (L322) > Cabin Heat issue solved
Tom1973
Finland
Hi, maybe this will help to someone who have problems to get heat inside.
I have L322 4.4L gasoline (2003) with aux heating. Lost interior heating gradually during summer and now when autumn arrived, its started to be really cold to drive.
Symptoms: Engine heats normally but no heat to inside, aux heater was running for only short period.
Checked the water pipes which goes to inside heater matrix. Some of those pipes where mild warm some just cold (tad difficult to check as engine was really hot next to hand).
Water valve behind the engine (pita to change) was the issue. It controls which water goes to heater matrix (engine or aux heater). the seals inside were swallowed and blocked.
I ended up changing also dual water valve next to suspension tower (easy to change) as it's old and cheap.
Recommended to buy BMW valves as those are cheaper than RR versions.
Below some pics.
Post #568241 28th Sep 2020 9:38am
Tom1973
Finland
small valve behind engine
Somehow pics are not uploading??
Post #568242 28th Sep 2020 9:40am
Tom1973
Finland
Here are the EOM codes for the Water Heater Control Valve LR066865 / LR040731 / JEO000010 / 6421690744402
Post #568244 28th Sep 2020 9:43am
p38arover
Australia
Re: Cabin Heat issue solved
Tom1973 wrote:
Water valve behind the engine (pita to change) was the issue. It controls which water goes to heater matrix (engine or aux heater). the seals inside were swollen and blocked.
Aux heater?
Recommended to buy BMW valves as those are cheaper than RR versions..
BMW part nos.? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #568271 28th Sep 2020 11:59am
Tom1973
Finland
Aux heater = webasto (fuel burning heater)
BMW code for heater valve is 6421690744402
Post #568276 28th Sep 2020 12:55pm
p38arover
Australia
Thank you.
Was the FBH only on diesel powered vehicles? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #568473 1st Oct 2020 5:36am
Tom1973
Finland
FBH was option for gasoline version too, just more rare and maybe only for Nordic countries (mine is that).
Post #568480 1st Oct 2020 7:49am
p38arover
Australia
Does it have a separate diesel fuel tank or does it burn petrol? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #568481 1st Oct 2020 8:03am
Tom1973
Finland
it burn petrol
Post #568490 1st Oct 2020 10:11am
Dolphinboy
I have one too on my UK 2004 AB. It was an option (and a bloody god one too!!)
It runs on Petrol.
Post #568492 1st Oct 2020 10:48am
p38arover
Australia
Thanks gents. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #568703 3rd Oct 2020 12:59am
