Home > Maintenance & Mods (L405) > Gummi pflege |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
It's time - I had my drivers door stuck shut with a bit of frost. Geoff |
27th Sep 2020 10:27am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35268 |
you beat me to it....only yesterday i was thinking that and flat battery's.... ... - .- -.
27th Sep 2020 2:07pm |
Yep, get them C-TEKS connected especially if you have remote heaters. Geoff |
27th Sep 2020 8:22pm |
I have used mine outside without problems but I tended to leave it under the car in case it rains. Geoff |
28th Sep 2020 6:53am |
Tom_T Member Since: 22 Jun 2020 Location: Essex Posts: 44 |
Awesome thanks for the tip Tom
28th Sep 2020 6:57am |
I also notice Aldi selling their charger again. I don't know why but I bought one last time, never used it because I have a C-tek - never used that much either but I did need it when it was really cold and I used the remote heater a lot with short journeys to work.
28th Sep 2020 5:05pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 |
The Ctek is splash proof (IP65), but likewise, personally I tend to place it on top of one of the front tyres as far back as possible so it's raised off the ground in the case of heavy rain, but still hidden away under the wheel arch, and connect it to the vehicle with a Ctek extension if needed.
28th Sep 2020 8:32pm |
on all 4 FF's i've owned , i have never used a battery charger......am i missing something? ... - .- -.
28th Sep 2020 8:38pm |
I never used to either Stan, but then again the vehicle also used to get driven reliably at least once every 2 weeks, most commonly for a decent long motorway journey, which definitely kept the battery topped up nicely.
28th Sep 2020 9:40pm |
Ever eith Gummi Phledge car door is frozen shut- I guess that’s what a bit of damp followed by -7 gets you ☃️☃️☃️B Geoff |
2nd Jan 2021 10:56am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
Mine too Geoff. -7 here in Brizzle area. Lock froze too so couldn't close door without using the central locking button inside! |
2nd Jan 2021 11:44am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
You can connect a Ctek charger in the boot area either directly to the 12V supply to the rear fuse panel or to a spare fuse position on the fuse board and an earth point. You can then pass a mains voltage cable into the boot area at either the extreme lhs or extreme rhs of the boot on top of the lower tailgate and close the upper tailgate without trapping the mains cable.
2nd Jan 2021 8:43pm |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 344 |
Or use a *very* long mains cable |
2nd Jan 2021 10:02pm |
