Home > Technical (L322) > Horn not working
SharkGill
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Horn not working
Hi All, I’ve had my L322 for a week now and I’ve now lost horn function. I did spend a bit of time pulling the duel horns out yesterday to test. They clicked when I applied 12v to them but did not make any audible honk. I put them back in the car but no sound is audible when pressing the steering buttons. I also tried testing for voltage and continuity when pressing g the steering buttons and nothing. Also check fuse 10 as listed on the fuse cover which is fine. My car is a late 2005 jaguar engined 4.4 petrol 6 speed and it seems that the manual is for the facelift model with the gear lever offset towards the driver.
I’m not sure if it has a relay for the horn as there doesn’t seem to be any visible space or covers for relays mounted in the glovebox. There looks to be a factory fitted 6 cd changer above the fuse box.
Could someone please advise on next steps please?
Post #568142 27th Sep 2020 3:43pm
dingg1
Your horns are finished, they should sound if you put 12v up them, change them out.
Post #568150 27th Sep 2020 4:57pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Re: Horn not working
Unnecessary quote removed
If it’s the same as my MY07, then there is a fuse and relay in the same box as the engine ECU under the bonnet
Post #568801 3rd Oct 2020 3:56pm
SharkGill
Just fitted the replacement horns which I tested beforehand but still no joy. I’ll check the fuse and relay under the bonnet. Thanks
Post #568870 4th Oct 2020 11:26am
SharkGill
It was fuse 16 under the bonnet. Thanks again
Post #568875 4th Oct 2020 11:46am
