Home > Technical (L322) > reversing lights
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
reversing lights
i got two pairs of led reversing lights from a fella on here and everything was great for a while , now when i turn the car on i get the bong of death with a check tail lights . before i put it into drive the reverse lights start to flash. i have changed to the second set but sill the same . i have also checked all the bulbs and they are fine . any ideas please
Post #567751 22nd Sep 2020 6:17pm
Harlin
please
Post #567815 23rd Sep 2020 12:07pm
DrRob
I fitted these https://www.ebay.co.uk/itm/253516614363
I can’t help specifically on your issue sorry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #567820 23rd Sep 2020 12:33pm
Harlin
thank you
Post #567824 23rd Sep 2020 12:46pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Ref Dr Rob's link,
I bought reversing / number plate and door mirror puddle ligts from the same people, no bongs of death. Thumbs Up
Post #567831 23rd Sep 2020 1:55pm
Harlin
have they started to flash
Post #567834 23rd Sep 2020 2:27pm
take out and leave out the reverse light bulbs and see if that makes a difference.......
also, check for water ingress in the near side rear cubby... ... - .- -.
Post #567835 23rd Sep 2020 2:40pm
Harlin
will do thankyou
Post #567838 23rd Sep 2020 2:58pm
Harlin
ok have taken out the bulbs ,still getting bong (i will leave them out for a while).have no water in the chubby ,is there any thing else i can do myself or do you think its a garage job . Thanks again
Post #567839 23rd Sep 2020 3:11pm
Strider
Nope, they all behave like "normal" bulbs.
Post #567843 23rd Sep 2020 4:16pm
Strider
I see we have the same car be it one year apart.
Anyway, do the instrument lights, exterior lights and approach lamps flash? as well.
According to my fuse board layout (front one behind the dash cubby box) fuse number 4 rated at 5amp supplies all of the above.
Id take the fuse out and check the supply with a mulimeter, if its a constant supply, maybe a local bad earth or wiring shorting somewhere.
Sorry cant be more help.
Post #567844 23rd Sep 2020 4:30pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Go with DrRob’s suggested bulbs, did all mine, along with the Powerful UK puddle lamps...looks great when you press the button on your key Thumbs Up
Post #567864 23rd Sep 2020 8:24pm
mjdronfield
I didn’t think the reversing lights were part of the bulb check system. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #567867 23rd Sep 2020 8:42pm
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
Mine flash just after ignition on. I also noticed when following, that my brothers flash occasionally when driving. 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #567896 24th Sep 2020 8:34am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
After reading this thread here last week, I purchased a couple of LED's via Dr Rob's link. Arrived in the post today and I must admit, it's a definite improvement. Can't wait to try them out in the dark now, and given that today is the shortest day of the year, there shouldn't be long to wait! Laughing
 The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #617099 21st Dec 2021 1:38pm
