Home > In Car Electronics (L322) > Reverse camera connections
CongoBoy
South Africa 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Hi All,
I'm in the process of putting in an upgraded rear view camera in my 2005 SC.
One of the previous owners had just joined the co-axial cable with tape.
Can anyone point in the right direction for the type of connectors needed?
Thanks.
Post #567586 21st Sep 2020 9:16am
i dont think there are specific connectors...if its just two bits of cable joined together then tape will be ok... ... - .- -.
Post #567593 21st Sep 2020 11:03am
CongoBoy
Hi Stan,
Thanks for the reply. I'll explain a bit more what I'm looking for.
I have ordered a replacement/upgrade camera. (See image below)
The connectors that it comes with should be a plug and play for the existing connections, of which the two wire block connector is still present (black and red) but the coaxial cable connector is no longer there.
I'm just looking to try and order replacement screw-in co-axial connector (Male, I assume?) for the wiring loom end to make it a better fit.
I have looked trhough all the various topics on the Forum but have yet to find what size/type of connector it is?
Post #567606 21st Sep 2020 11:52am
Weegie
There are coax connectors available. https://www.elecbee.com/fr/38-connecteur-uhf I have used them for antenna feed connections. It's just whether you need to go to that extent for the rear view camera. John
GAP iiD BT
Post #567607 21st Sep 2020 11:56am
CongoBoy
Thanks Weegie.
Just a case of keeping it neat and open to other options!!!
I've been busy trying to measure the damn cable size!!
Cheers.
Post #567609 21st Sep 2020 12:11pm
Brian Considine
Rather than follow the "bodge it" advice you could use these if you don't want to solder ;
https://www.ebay.co.uk/itm/5pcs-RCA-Plug-m...SwpBdeJkKB
or this type (with suitable female sockets) if you are OK with soldering ;
https://www.ebay.co.uk/itm/5-Yellow-Phono-...Sw3-9b9~pH
I just can't understand anybody advising "tape joints" (even on signal cables - in anycase, the signal needs to be shielded) especially on a vehicle as complex as a FF. 2003 Range Rover Vogue TD6
Post #567687 22nd Sep 2020 8:05am
Ianb4310
CongoBoy
Where did you get get your camera from do you have a link ?
Post #567701 22nd Sep 2020 9:55am
CongoBoy
Hi Ian,
I bought it on Ebay but here is the sellers website: www.luxurylandroverupgrades.com.
They have several options.
Post #567703 22nd Sep 2020 10:12am
Ianb4310
Post #567709 22nd Sep 2020 11:40am
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
IMHO yes you should be using a coax connector. I fitted the same camera as you however my car still had the correct coax connector in place.
The connector Land Rover used is a industry standard, unfortunately I don't know what it is called but a trawl of the websites of RS Components and Farnell should help you find it. Both sites have detailed data on every connector they sell, so measure the cable diameter and the connector diameters and use the filters to help.
I had a quick look for you but without success ( I don't have the cable data to hand as mine is all assembled) so it will take some effort and time.
You could call luxury land rover upgrades, they should know what connector is used.
Good luck
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #567785 22nd Sep 2020 11:10pm
CongoBoy
Hi,
Yes I think I've found it. Its a SMB-C female basket connector, similar to a Fakra type connector.
It's actually difficult to find. The coax is only 2mm width.
But hoping that when it comes it will be a quick reassemble, as I have alrerady mounted the new camera in place.
Post #567791 23rd Sep 2020 8:07am
supershuttle
Funny enough I fitted a new camera back in the day. I just soldered the wires and used some heat shrink - perfect - still working today AFAIK. I did take the trouble to ensure that the screening was preserved but I tested (whilst waiting for heat shrink to arrive) with just the wires twisted together again no problems. My experience would suggest that plugs and sockets are often the cause of problems (that's probably why I didn't bother or maybe it was cost and availability - I really cant remember) and of course depending on how the plugs and sockets fit you might have to get the cutters and soldering iron out anyway.
A direct soldered joint will always be better than a plug and socket. Geoff
Post #567794 23rd Sep 2020 8:53am
Ianb4310
CongoBoy
Do you have a link to the one you bought?
Post #567886 24th Sep 2020 5:22am
CongoBoy
This is the one I bought:
https://www.ebay.co.uk/itm/Land-rover-Rang...2749.l2649
I stripped out the old camera from within the housing and reseated this in it.
I've set-up and installed it back in the vehicle and I'm just waiting for a new connector to try it out.
Post #567887 24th Sep 2020 6:04am
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
I'm pretty sure you can get these for around £10. That's what I spent on mine from eBay in 2018 and it works a treat. You do have to overcome the connector issues, but as others have indicated, soldering and heat shrink works well.
Rob 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #567897 24th Sep 2020 9:21am
