Home > Technical (L322) > TD6 egr thermostat |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
https://www.fullfatrr.com/forum/post375574.html
21st Sep 2020 9:12am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
You probably want this from the wiki, does egr 'stat and main 'stat
21st Sep 2020 12:39pm |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 |
I’m going to fit a egr bypass from jgs does this mean I don’t need the egr thermostat??
21st Sep 2020 2:06pm |
The EGR blanker does not eliminate the egr cooler/thermostat, it just blocks the exhaust gases from going into the inlet manifold. So no. However, you may have seen in your research that some have removed the egr cooler/'stat. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
21st Sep 2020 2:59pm |
Yes ! Is that just a case of removing the egr thermostat then capping the pipes? |
21st Sep 2020 4:22pm |
Follow the first link up above, then the one there to find the AULRO link.
21st Sep 2020 5:25pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
If you are removing the egr valve and wish to ensure there is no coolant flow through the redundant egr thermostat without renewing it all you need to do is block it. To do this you need to remove the top right hand connection, when looking down on the thermostat and insert in the exposed end of the thermostat a 12mm cut length of stainless steel 12mm threaded rod or bolt wrapped with a few layers of ptfe tape to ensure a snug fit. This effectively plugs the egr thermostat ensuring no coolant flow whatever the state of the thermostat. Then simply reconnect the pipe. No need to worry about the plug moving, it can't go anywhere.
21st Sep 2020 8:23pm |
Thanks 👍 |
21st Sep 2020 8:26pm |
Nicedayforit do you mean where the yellow arrow is on my my picture??
22nd Sep 2020 4:04am |
Yes that is the pipe you unclip.
22nd Sep 2020 7:16am |
