Home > Maintenance & Mods (L322) > what's this pipe for?
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
where does this pipe go to??
its a vacuum pipe which end at around the air box.
I've read on other threads regarding air box removal to "remove the small pipe which attached to the side of the air box" but on my 2010 there is nowhere on the air box to connect it to? currently, it just dangles and it doesn't seem right that a vacuum pipe is not connected to anything?
Post #567298 17th Sep 2020 10:45am
MTG2020
In the workshop manual, it's shown loose and is the breather tube for the front differential.
Post #599268 30th Jun 2021 6:47pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Dexion I had exactly the same problem though mine is the 3.6. once it was put back on along with another pipe I found loose that someone on here told me where it went, the car ran so much better. The nipple on mine it should attach to is actually on the air filter cover you take off not the filter box itself.
Look here https://www.fullfatrr.com/forum/post598953.html#598953
Hope this helps.
Post #599322 1st Jul 2021 9:24am
