Home > Maintenance & Mods (L322) > Transmission sump plug |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 125 |
Is it the sump plug on the bottom or the filler plug on the side? For the TD6?
14th Sep 2020 11:35pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1526 |
Take it to SuperCheap and see what will fit. That's what I did for the engine sump plug when the sump was stripped. I bought one with more thread as a temporary measure until I could drop the lower sump and drill, tap, and fit a HeliCoil. Sump plugs aren't rocket science. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
15th Sep 2020 3:45am |
Tom Paine Member Since: 11 May 2015 Location: Townsville Posts: 47 |
P38, I begin to suspect you're right. Advanced factors and LRDirect have both sent my money back and Island 4x4 can't get any. It's wreckers or get an old sump and hang around Supercheap and Boltmasters.
15th Sep 2020 7:26am |
If it's not refitted, take with you to SuperCrap or Boltmaster. If you don't have any pitch gauges, the latter will tell you the size.
15th Sep 2020 11:56am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
If it's a TD6 then it's the GM5L40E transmission which is used on vareity of other vehicles abliet in slightly different configurations, e.g. 2WD M82 version on BMW E46 or E39 diesels or even some Holden Commodores over there.
15th Sep 2020 12:05pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
find a near match nut and bolt. Weld nut to sump over hole and use the accompanying bolt ( with a washer of course ) |
15th Sep 2020 6:16pm |
Gentlemen, thanks for your thoughts. I was looking at wreckers and possibly buying the whole sump pan, but the idea of searching by box number hit the spot. I find that this box is fitted to BMW 3 and 5 series, and more to the point, to Holden Commodores 2004 to 2010.
27th Nov 2020 4:53am |
