Home > For Sale & Wanted > [SOLD] 2008 L322 3.6 TDV8 - Full Service History
ctjfb
Advert order number is 200908-960
£5300 OVNO
This car has done 172k miles and comes with a full service history and has benefited from the following recent maintenance
Within the last year:
All fluids changed (Engine, gearbox, transfer box, front & read diffs, coolant, power steering, brake fluid)
All filters changed
Full auto gearbox preventative service with full fluid change, filter change, new mechatronic seals & full set of solenoids
Brand new genuine Land Rover 20 inch alloy wheels (5) and new Michelin tyres (2k miles ago)
Front air suspension struts replaced
Rear shock absorbers replaced
Engine serpentine belt & tensioner changed
Fuel injection leak-off pipes changed
Replacement tow-bar and new 13pin electrics
Rear suspension knuckle bushes
Front & rear anti-roll bar drop links
New Battery
Air suspension compressor fully rebuilt with new piston, cylinder, exaust&delivery valves & rebuilt dryer
Within the last 3 years
New Inlet Manifolds
New front & rear discs & pads
The car runs & drives beautifully - no clunks, noises, vibrations etc.
The climate control is ice-cold
This car also benefits from a significant ICE upgrade!
A NAVTool unit has been fitted that adds Apple CarPlay & Android Auto to the factory ICE system.
All the the existing functionally is retained fully, and this works with the factory touch screen.
This means you can use SatNav such as TomTom, Sygic, Waze navigation as well as standard IPhone music apps etc.
The car is also fitted with the 2010+ style paddle shifts for the auto box
This uses genuine LR steering wheel parts & an interface box described in:
https://www.fullfatrr.com/forum/topic55147...ddle+shift
On eBay also - auction due to end on Friday
Any inspection welcomed
 Chris
2012 TDV8 4.4 Westminster
Post #566616 8th Sep 2020 3:04pm
Weegie
GLWTS , Chris.
What are you replacing it with? John
GAP iiD BT-Sold
Post #566662 8th Sep 2020 8:12pm
ctjfb
I'm not replacing it directly ... I just don't have any use for it, and I it is just a waste having it sitting on the drive looking at me Sad
It isn't good for the car either to not be used ...
So - taking a break from Range Rovers - until the next one Smile - [It's my 8th - so I guess I'll get another sometime]
Chris Chris
Post #566663 8th Sep 2020 8:22pm
Weegie
It's a nice,looked after example at a good price for someone. Thumbs Up John
GAP iiD BT-Sold
Post #566664 8th Sep 2020 8:30pm
