Home > Technical (L322) > Front Struts Conundrum! |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 |
Are they different manufacturers? Paul,
6th Sep 2020 2:19pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35415 |
aftermarket or OE? ... - .- -.
6th Sep 2020 4:30pm |
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 |
Well every day is a school day! Both stated as OE but bought from different suppliers, so likely to be different manufacturers!! My error. Another interesting fact is that the pressure required to push the dampers down is different also. Thanks for your replies, lesson learnt. |
6th Sep 2020 5:21pm |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 |
Chinese Garbage by any chance?
6th Sep 2020 5:24pm |
Unable to confirm country of origin as both supplied in plain box and no markings on units. Adverts stated OEM with 2 years warranty and from a UK based company. |
6th Sep 2020 5:51pm |
Sounds fishy...
6th Sep 2020 8:50pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
not sure the bag length is a problem because the pump will add air untill the height sensor says 'enough'.
6th Sep 2020 9:02pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 901 |
Why did you replace the drive shaft and carrier bearing?? |
7th Sep 2020 8:02am |
The "old" ones I refer to are the units that were fitted three months ago. Having had the vehicle for over 5 years and driven many hundreds of FFs (worked for LR) after the "old" ones were fitted the front of the car seemed to bounce as if there was no rebound damping from the shock absorbers. So after the most recent work, it is now back to what I think it should drive like.
7th Sep 2020 9:33am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1393 |
You have a supercharged. Dont they have different shocks on the front from the normal ones ...
8th Sep 2020 8:32pm |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
The SC ones are different as the engine is over 100kg lighter than the diesel. |
9th Sep 2020 8:40am |
