Home > Technical (L322) > TD6 Slow to engage drive in the morning |
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 |
Soooo.......after reading this archive thread from 2011
6th Sep 2020 9:18am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 788 |
That Lucas stuff is incredibly thick and only increases the viscosity of the existing fluid, check out the lab tests on youtube. I would presume that would slow the flow down at cold temps. Are you using dex 3 or full synthetic fluid? When you changed the filter did you get the old seals out, they can be really stubborn and tight. Also, did you use the correct filter, there are 2 types for the GM Box, the correct one has the pickup 1cm lower than the other. When I did my 1st fluid and filter change 50000km after a rebuild I found it had the wrong filter, see the attached photos, the correct one has the black bar which lowers the pick-up
7th Sep 2020 2:03am |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
If you have a GM gearbox then this is what it was designed to have inside it
8th Sep 2020 1:57pm |
Just a quick update on this one, After greasing & using WD40 on the selector each month.
5th Jan 2021 7:49pm |
