Home > Technical (L322) > Leak from above the front diff |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Rear output seal which is higher up on the diff? Have you cleaned it up with brake cleaner topped it up and gone for a short drive to see if you can source it that way ? Current stable:
21st Jul 2020 9:28pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
if not the diff itself, the secondary turbo sits above the diff
21st Jul 2020 9:55pm |
coopss any update on this?
4th Sep 2020 11:26am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
I had 2 oil leaks around that area:
4th Sep 2020 2:17pm |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
It’s not using any oil at all and there is nothing on the floor after sitting for a few days.. it’s also had both new turbos.
4th Sep 2020 9:05pm |
