Home > Technical (L405) > Dash display throwing up loads of faults |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Check alternator output, earth straps to body (not battery terminal ends) and interrogate any fault codes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
1st Sep 2020 1:20pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
after the battery fitting did you reset the steering parameters? ... - .- -.
1st Sep 2020 1:23pm |
Brightondefender Member Since: 29 Jan 2013 Location: East Sussex Posts: 36 |
Thanks for the replies guys. They kept the battery terminals live when they did the switch over by hooking a backup battery to the leads, but then it was just a straight in and out swap. Nothing was reset as such.
1st Sep 2020 1:33pm |
I have just had a diagnostics run at my local garage and they say that the dash pack has failed and only Land Rover can fix it. Has anyone any ideas on this? |
2nd Sep 2020 8:24am |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 |
I would be tempted to do a "power down reset" IE disconnect the +ve lead for a min or 2 . Tracker will phone you unless you preempt it .
2nd Sep 2020 10:21am |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
when you put the new battery in did they tell the power gateway module a new battery was fitted - if the previous battery was failing and you haven't told the car a new battery has been fitted you could get these issues Current Fleet:-
2nd Sep 2020 4:05pm |
