Home > Technical (L322) > 2011 fuel gauge |
physio Member Since: 31 Aug 2020 Location: Essex Posts: 6 |
Have the same issue with fuel guage showing empty. Has anyone any pictures of how to remove the clamps / springs from inside the tank? Just in case I have to remove the internal stuff. |
1st Sep 2020 10:31am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
1st Sep 2020 11:46am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Physio
1st Sep 2020 12:55pm |
Thats great. Thanks to you both. One more question. Whats the best connectors to use once the old plugs are removed? And do they have to be 'diesel' proof? |
1st Sep 2020 1:26pm |
IIRC I simply used in line crimps suitable for the cable size and they weren't
1st Sep 2020 2:12pm |
Thanks Richard. Will do. Will let you know how i got on. |
1st Sep 2020 2:30pm |
Good luck Cheers
1st Sep 2020 2:40pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
Thanks for the great posts people. Dealer i brought the car from had not heard of this fix!! so they are happy as only cost them the labor to apply the fix.
4th Nov 2020 3:42pm |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 149 |
I too seem to have this problem, suddenly fuel gauge showing zero and not knowing of this sender fault I filled her up !
22nd Jan 2023 12:16am |
Old-un, most of the sometimes three, four, or five connectors are below fuel level, it's best to replace all or you may end up doing it again.
22nd Jan 2023 9:14am |
Finally bit the bullet and arranged for an indy to sort it for me. Garage was 11 miles away and I set off with my wifey following, all done in limp mode and as expected the vehicle stopped every 500 yards but restarted every time 'till I eventually hopped to my destination ( just keep away from motorways ! )
3rd Feb 2023 8:39pm |
NJPovey Member Since: 29 Dec 2020 Location: Sussex Posts: 11 |
Last year the in tank fuel pump on our old TD6 packed up. I wasn't wanting to spend lots of money on the 150,000 miles workhorse so bought a cheap pump unit complete with the fuel level senders.
13th Jul 2023 9:33pm |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 144 |
I have just done mine.
27th Mar 2024 12:18pm |
