![]() | Home > Technical (L322) > Engine noise - clattering - 4.4 vogue 2005 |
200AD Member Since: 17 Apr 2019 Location: Leicestershire Posts: 18 ![]() ![]() ![]() |
First port of call; check your spark plugs are tight. Mine sounded similar before I fitted a new set in a tearing hurry! |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 515 ![]() ![]() |
Glenhendry,
For example (second one sounds like yours) - although I agree with 200AD that from the camera position you have it also sounds like a farting loose plug as well!!
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3221 ![]() ![]() ![]() |
Chain guides |
glenhendry Member Since: 14 Jan 2019 Location: Brisbane Posts: 12 ![]() ![]() ![]() |
Thanks all, you were correct of course.
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
I’ve done this job before and, whilst time consuming, it’s not too bad. I say that given it’s the first engine I’ve ever worked on so it could be argued it was a baptism of fire! However, I’d do it again if the need arose. Personally given the time it takes, just replace the chain and don’t try and save a few dollars. If it subsequently jumps then you’ll be looking at rebuilding heads etc.
holidaychicken on this forum did a great "how to" so do a search and you will find lots of info about the tools required, steps etc.
Here's a wrap up, a the job is now done. Thanks again for help. Link here: https://www.aulro.com/afvb/l322-range-rove...build.html I have completed the job. It was huge wrt the number of hours, and there were some tricky bits, but nothing impossible. I ended up with some new tools in the garage. A big thanks to FisherX for the loaner of timing tools. They will get back to you soon. I decided to buy the Vanos rebuild orings kit and I had to wait FIFTY-SEVEN days for them to arrive, hence the huge delay in the job finalising. Rebuilding the Vanos' was not difficult. Made me feel fuzzy too, but compressing the press was hard work, and the vice and work bench were tested. I did replace the jesus bolt, and the front main seal, it was simple to remove the old one and drift the new one in carefully without the fancy seal removal tool. All the old gaskets were solid and brittle. No wonder there were leaks. All the connectors and tubes and hoses survived the ordeal. The oil dipstick tube in a total PITA. I could NOT get to the bottom of it to check the oil seal and clamp, and I am worried about that bit. A very very neat trick to hold the new gaskets onto the cam covers while you lower them on at the end of the whole job is to zip tie them to the cam cover (about 25 of them) - then snip them off once they are in place - thanks for that tip. I turned over the engine 50 times via starter with fuel relay removed and the battery fully charged. Then it started up pretty much straight away when fuel relay reinstallled. It sounded tight and amazingly quiet. I took out 8 lifters and 0 of them squeezed like I had seen in some youtube videos. I couldnt afford to replace them all, and since I had had no lifter noise previously, I left them in. Timing the engine is not that difficult, and there is plenty of DIY videos. Neither of my Vanos's would beep the closed circuit at full retard with the DMM like the video suggest, but the Besian Systems instructions said that wouldn't always occur. I was confident that I had full CCW retard on the cam so I went ahead anyway. GAS webpage instructions were great: Instructions for the G.A.S. Master Cam Timing Tools for the BMW M62-M62tu Engine | German Auto SolutionsGerman Auto Solutions. All the coolant hoses are easy to relocate, as are fan belts. I have smooth running, no coolant or oil leaks, with no fault codes initially, but after 10 hours I got "Lambda control adaption faults" on both banks which have not returned since cleared. I suspect fuel map is changing and I should probably clear all the adaptations with new timing belts and new vanos's. Overall I am very happy. There was very considerable relief when she fired up and ran smooth. I spent $1420 on parts (timing chain guide kit, and vanos rebuild kit), which included ~$200 in tools. Total hours on spanners 70. Research ~22hrs. Someone with more skills or more tools could probably half that. Will be testing it by towing the camper this weekend. |
