![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
Greg,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Yes the IID can tell the ECU you have fitted a new DPF.
. Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 27th Aug 2020 8:25pm. Edited 2 times in total |
I would add that the IID give a hearty warning about resetting the DPF.
Ian May be able to tell us in more detail how his was reset to zero , .. what tool they used etc., but only when someone does it all using only an iid will we know for definite.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 499 ![]() ![]() |
I know this must have been said many times, but what a brilliant write up, extremely helpful, thanks GGDR! |
paulparry82 Member Since: 04 Mar 2020 Location: Merseyside Posts: 21 ![]() ![]() ![]() |
I agree - this thread and the contributors are life savers when it comes to DPF issues.
Ianclark1275 Member Since: 11 Apr 2020 Location: York Posts: 67 ![]() ![]() ![]() |
Hi all
RRD Member Since: 19 Mar 2014 Location: Antwerp Posts: 40 ![]() ![]() ![]() |
Hi Guys,
Sudden change.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 332 ![]() ![]() |
Hi RRD, yes Greg is 100% correct. You've had a sudden change so there's a checklist to go through:
Thanks for the help guys, keep you posted!
Did some more reading, I will check the hoses tomorrow, I'm pretty sure they're still the original ones.
Dr Rob will know where to get the silicon hoses.
Unfortunately not for most of it - the smoke test is the first go-to. If the EGR or throttle bodies are open incorrectly they can tell that on their diagnostics as they can see the angle / degrees to which they are open; but that doesn't cover it if there's a chunk missing from the gate... It seems like a bit of a maze to start off with but the people on here have a map!! |
So I checked the tubes yesterday, and to the naked eye I don't see anything wrong with them. I checked the 4 tubes indicated in red:
