Home > General > Seriously considering purchasing a late L322 - Advice needed
jackie-o
Netherlands
just my two pence worth....
It all depends on the specific car and what has already been done.
There is by now a really comprehensive list of issues that affect more or less all cars so you know what will need fixing at some point. From there you can check off the things that have allrady been taken care of.
The costs tend to add up pretty quickly....
That said, great cars and great value for money in my opinion RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #565679 27th Aug 2020 2:45pm
DrRob
Typical Essex Boy wrote:
£5k for repairs? Even in the first year without knowing what to expect, that seems really excessive Shocked
I'd expect £2-3k in the worst scenario on things that could go wrong. But I'd be getting a 6 month, with a possible extension, warranty that would cover engine/transmission faults with it. I'd hope nothing major would go wrong for the first few thousand miles at least.
I was unlucky with my turbo replacement but without that expense it would have been about £1500 in year 1 Thumbs Up
Now that I’ve spent some on it I feel it’s in tip top condition Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565694 27th Aug 2020 5:17pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Did the O rings and oil cooler gaskets myself.
Not fun granted, but pretty easy. Parts came to less than £30. Genuine gaskets.
8 months down the line and no leaks since...so I must have done something right 😂 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #565699 27th Aug 2020 5:53pm
D3Jon
Bought our 2011 TDV8 4.4 Vogue SE around 2.5 years ago, it had just under 80K on the clock and came with a full main dealer service history, previously run by senior manager at Guy Salmon LR.
It's never been a problem, never let us down, now has 103K on the clock, with just the usual L322 stuff to fix / replace, most of which I only did this year:
1) Discs and pads all round
2) Handbrake shoes
3) 2 x lower front suspension arms (balljoints had play)
4) 2 x upper front arm bushes (bushes worn)
5) 1 x rear upper hub knuckle joint
6) 1 x Front height sensor
7) Rear wiper motor - water leak
8 ) Auxillary belt tensioner and belts (the original tensioners crack and squeek)
9) Engine oil and filters
10) Wiper blades
11) 4 x Tyres
That's it, around 25K miles, nothing expensive or exceptional. A big car like this goes through pads / discs and front suspension ball joints fairly quickly as expected.
Not had any issues with leaking oil coolers, nor any exhaust smoke from 2nd turbo drain, haven't looked if it's been modded though.
All in all, these cars are very reliable. If you're handy with the spanners costs can be kept very low and of course diagnostics is a doddle with the GAP IID tool, with lots of tech support available. I also run an Audi and the diagnostics (Odis) seems to need a masters degree in programming by comparison.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #568416 30th Sep 2020 12:07pm
