Home > Technical (L322) > DPF red - visit dealer
Ianclark1275
Hi all
I went on a Landrover experience last week
My friends said did they take you to the side of the motorway and call the RAC lol
Anyway, I’m now trying to get to Nairn in Scotland for our weekend away and the red warning has come on
Currently just north of Lockerbie on M74
It’s in limp mode and I’m a bit stuck
Can I use the Gap to regen ?
I can’t find anything on the forum that says if it’s possible or not
I’ve cleared the code and it immediately comes back on
Any help appreciated
Looks like I’m on the real landrover experience this week !
IC
Post #565639 27th Aug 2020 10:46am
Baltic Blue
No, sorry but the Gap iid can’t force a regen.
Did it come on after miles of motorway driving ?
If so, most likely to have been caused by an air leak in the air intake.
A split in one of the 4 short plenum hoses is favourite.
Post #565642 27th Aug 2020 10:57am
Ianclark1275
Thanks Mike
Yes it did come on after 100 miles of motorway driving
I will stop at the next junction and check the 4 hoses
If I use cruise control after half an hour of motorway driving I get a red warning so I don’t use cruise control anymore maybe the faults are related
I didn’t get a yellow dpf warning it went straight to red.
Post #565645 27th Aug 2020 11:07am
Ianclark1275
We are calling into strathern Engineering on the A9 there going to have a quick look
Thanks IC
Post #565650 27th Aug 2020 11:53am
DrRob
I bet a hose is split somewhere causing an air leak.
Either one of the 4 plenum hoses or the join between the intercooler and throttle body or an inlet manifold is split.
A high pressure smoke test will reveal any leaks. Has to be high pressure. A "normal" pressure one that most garages have will not suffice.
Good luck Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565651 27th Aug 2020 12:04pm
DrRob
MMP Land Rover in Dundee run by Mick Park is another good option Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565652 27th Aug 2020 12:05pm
Ianclark1275
We are at Strathern Emgineering off A9
They are looking at it now
They are sorting it out now
First class service if anyone round here needs a LR garage
Highly recommend
http://www.strathearnengineering.com
Post #565664 27th Aug 2020 1:23pm
Mr Tee
Used Strathearn loads, it's where the local MD goes when they are stuck, great lads. Thumbs Up
Post #565665 27th Aug 2020 1:25pm
Baltic Blue
Good news...glad you got there and hope it is a quick fix.
Let us know what they find... it’s how we all learn from other members experience.
What was the soot mass reading when you got there ??
Post #565666 27th Aug 2020 1:27pm
Ianclark1275
Im trying to get up the road so I needed to on my way ideally
The girls and wife were sat waiting so here’s what we did
DPF cleaned with forte cleaner (Added and taken for a drive to clean out)
Level reset to 0
Light out and I’m monitoring the build up, it’s going Up slowly, then when I get to where I’m going they recommend a forced regen
That’s it for now
Currently in a traffic jam on A9.
Thanks for your help
IC
Post #565683 27th Aug 2020 3:24pm
Ianclark1275
Reading was 34 when I got there
0.1 after cleaning
Now 4.0
Post #565684 27th Aug 2020 3:25pm
DrRob
What was the root cause though? DPF doesn’t go red for no reason Whistle
Did they find an air leak? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565692 27th Aug 2020 5:09pm
Ianclark1275
Arrived in Nairn and all is well
No other faults were found as to the cause of the red warning
I suspect if I’d left it and asked them find the root cause they would have
He had it on ramps and couldn’t find anything wrong
I was in and out with working car within 1.5hrs for £80 so I was happy enough given the circumstances
It Just came up with the same fault I posted on there computer
We watched the DPF rise over the next 2 hours to from 0.1 to 18.9 the exhaust gas temp B1S2 went from 300 deg to 640 deg and the number dropped to 8 and was slowly falling. So we all cheered and looked to regen and I turned the gadget off.
It’s booked into JAS Landrover at the end of sept for root cause to be determined also the cruise control REstricted performance issue also , maybe related , don’t know.
Thanks to you all for taking the time to reply
IC
Post #565705 27th Aug 2020 7:07pm
DrRob
Joe at JAS is a thorough chap so keep us posted Thumbs Up
Enjoy the hols Very Happy Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565707 27th Aug 2020 7:18pm
Ianclark1275
Will do
Just ordered room service to reduce mingling about in restaurant Razz
Post #565709 27th Aug 2020 7:26pm
