![]() | Home > My Range Rover > Hello from Oz - new RR and new member |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
thats an impressive shine , welcome to the forum.. |
FeralRangie Member Since: 22 Aug 2020 Location: Canberra Posts: 5 ![]() ![]() |
Welcome advice on:
try a search , its all there..
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 ![]() ![]() |
I did a cold air intake on mine but the air comes in from lower part of the bumper so may not be to your liking, I will do a write up on it shortly along with a few other things i have done like just installing a catch can which i think might be a world first on one of these engines |
Thanks Dave - look forward to seeing the write-up/pics of cold air intake. I don't do deep water crossings so my main focus is a set-up that allows fitting of a temporary foam sock for dust...snorkels obviously make that easy.
I had a remap done and incorporated a map out of the egr at the same time.. I actually blanked mine off with my own approach by making plates which fit to the rear of each exhaust manifold where the piping (all now removed) for the egr starts it's journey.. It has been flawless... Engine is noticeably quieter with the egr blanked and imo better milage and smoother running engine is also noticeable which makes perfect sense
Thanks Dave - will fit the blanking plates and then look at ECU mod options. |
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
Don't you risk a $20000 fine if caught tampering with any emissions control gear that was factory fitted, or is that just for deleting the soot collectors DPF delete, or only in WA? "Gloria" 2002 L322 Voguish V8 LPG - carcass
Fortunately Oz L322s aren't fitted with DPFs and there's no inspection of things like EGRs. I'm sure EGRs make sense to pass Euro standards when a vehicle is brand new...however, I fail to see how it's environmentally friendly to have a vehicle that runs worse, uses more fuel and can potentially blow a turbo/motor through an EGR that is in less than new condition. |
I like your answer ,
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 ![]() ![]() ![]() |
Nice truck. Enjoy. |
