Home > Technical (L405) > Suspension rising to extended setting
OnslowSW7
United Kingdom 2017 Range Rover Autobiography SDV8 Mariana Black
Hi!
Firstly thanks for a great forum, which helped me choose my most recent range.
However a strange intermittent fault has developed. About 1 time in 5, when I turn off the engine the suspension rises to the extended position rather than dropping to the access height. If I estuary the engine, I can manually drop the suspension.
The car is a MY17 4.4 AB.
Has anybody come across this issue before?
Thanks!
Post #565394 24th Aug 2020 9:12pm
The only times ive come across issues like this was when mice had been eating wiring & when a wire had chaffed under the seat and was arcing out the can line...
Oh and welcome along sir Thumbs Up
Post #565405 24th Aug 2020 11:00pm
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
HI
If its the same problem I had it needed the bronze outlet filter on the air compressor for the suspension changed which is under the floor in the boot, you will have to remove the spare wheel and then you will see the plastic cover over the compressor, remove all the metal clips and the top will come of then you will see the filter which unscrews , you can leave it off while you get another one.
Because the air can't get through the filter fast enough the car takes to long to lower and it thinks there is something under the car and sends it up to extended .
Hope this helps. Thumbs Up
Post #565410 25th Aug 2020 12:04am
OnslowSW7
Thanks chaps- sounds like a trip to the dealer and (hopefully) a warranty fix...!
Post #565477 25th Aug 2020 5:35pm
