Home > Technical (L322) > Sitting on its bum with fault code C1A03 |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
You almost definitely have a leak; possibly a sensor issue too. Get the leak fixed, clear the codes then see if the sensor fault re-appears. If you still have a sensor fault you'll need a new sensor.
10th Aug 2020 7:46pm |
tinribs Member Since: 23 Jun 2017 Location: UK Posts: 20 |
Thanks for the reply RRL322!
10th Aug 2020 9:51pm |
Well the saga continues and I've not even managed to get it in the garage yet!
24th Aug 2020 9:19pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1204 |
Others might be able to give more info than me, but I've heard that if you are in off road mode and the car gets beached the suspension will go into extended mode to try and clear the obstruction. The only way, as I see it, that it can do this is from the sensors. Are all the sensors attached properly? |
24th Aug 2020 9:56pm |
Thanks Kevin - I'll have a look at the sensors. |
26th Aug 2020 9:29am |
