![]() | Home > Technical (L322) > Tyre valve replacement with TPMS |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
The valve stem is separate to the sensor which is just attached by a screw to the bottom of the stem. If it is just the valve insert leaking it can just be screwed out and replaced, if it is the rubber stem you will need to go to a tyre fitter.
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
Thanks Keith, that is good to hear |
