Home > Maintenance & Mods (L322) > Time for a gearbox flush and other TLC items |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
What gearbox do you have fitted?
22nd Jul 2020 7:06am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 930 |
5HP24 in mine it's the 4.4 petrol so usually a pretty good box. The old oil came out black. As I'm doing a bit of tlc on the old girl it's getting a new rad and I'm gonna flush the oil cooler out and check the oil lines as iv had a mystery oil leak I cant find since iv had the car. |
22nd Jul 2020 7:26am |
2nd flush completed today gonna run around in it for a bit before doing the final refill and filter change.
23rd Jul 2020 7:50pm |
Completed my 3rd and final flush plus filter change today. Gearbox silky smooth. I improved on my previous method of refilling by using a 10 litre garden spray bottle connected to my electric pump.
20th Aug 2020 9:46pm |
There is something very satisfying about changing all the various fluids on a Rangie 👍
21st Aug 2020 7:44am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4313 |
Jim - you're right. I got a buzz around doing my oil and filter change on the 4.4 using my 10L vacuum suction pump. Very clean and easy to do. Highly recommend it over dropping it out of the sump.
21st Aug 2020 8:31am |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 |
There's a good South Main Auto video Eric O posted recently where he did a 100k service on a Mazda 6. He just sucked out the PAS fluid from the reservoir, actuated the steering and repeated until the fluid looked clear - see from 13:40 in this video:
21st Aug 2020 9:39am |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
DO NOT touch those plastic clips that hold the pipes on the cooler. After 3 days outside the factory, they turn to glass and disintergrate when so much as looked at. You then need the whole bloody pipe as clips are not available separately . Ask me how I know...... |
21st Aug 2020 10:00am |
I have no intention of touching them.once I found out there not the cause of my oil leak. I even bought the propr bmw removal.tool just incase.
21st Aug 2020 1:52pm |
Both diffs done today 1 litre of milky old diff oil from the rear and 750 mils of clear but dark oil from the front. Used my electric pump to refill both.
29th Aug 2020 4:44pm |
Wow almost 5 years ago the cars still going well I'm about todo the same on my 5.0 s/c regarding gearbox service to see if it cures a slight shudder and revs bouncing about 100rpm.
10th Feb 2025 4:46am |
