Home > Technical (L322) > Suspension & Access Mode not working!
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
For some unknown reason my cars suspension will not rise / lower or access mode work? Just stays in normal ride mode. The button goes to the different heights but nothing happens. I dont get any strange noises etc!Any ideas?
Big Cry
Post #5649 18th May 2009 2:23pm
Landrovered
United States 2003 Range Rover HSE 4.4 V8 Giverny Green
Start with the simple stuff...Is the upper tailgate ajar or does it think that a door is open? 93 NAS 110, 72 SIII 109, 93 RRC LWB, 03 RR HSE
Post #5650 18th May 2009 2:27pm
Full fat not diet
Tried those before with no joy
Post #5652 18th May 2009 2:31pm
Could be the valve that is blocked inside the boot area , housing is underneath the spare wheel i got mine replaced with the new modified part that LR assistance fitted
Post #5653 18th May 2009 2:33pm
Landrovered
Is it throwing any codes?
Stuck valves, compressor overheat and faulty pressure valve would freeze in normal height but should throw a "suspension inactive" code 93 NAS 110, 72 SIII 109, 93 RRC LWB, 03 RR HSE
Post #5654 18th May 2009 2:34pm
Full fat not diet
i believe my steering rack could be on its way out but not yet had it diagnosed which could be linked
Also a while back the HDC & Air Suspension innactive lights came on but dealer replaced a sensor after third go of trying and that was then fine.
Post #5655 18th May 2009 2:36pm
Full fat not diet
I wouldnt know if mine was ok or not but will have a look - i take it it is under the spare?
Post #5656 18th May 2009 2:38pm
Yes you should see the black housing when you lift it up
Post #5658 18th May 2009 2:41pm
