Home > Technical (L322) > L322 Vogue Windows Erratic
Brian Considine
Sitting in the car today with all windows open about 2 or 3 inches and both front windows went all the way down on their own, door mirrors started "twitching" and now the front windows will not raise - the rear one did !
The switches for the font windows do nothing but trying to use the rear switches results in the door mirrors folding/unfolding.
Tried pulling the fuse for 30 minutes but did not appear to change anything.
Leaving the battery disconnected tonight to see what happens.
I've looke in the wiki & did a search but cannoit find a similar issue.
Any help would be appreciated. 2003 Range Rover Vogue TD6
Post #564783 16th Aug 2020 10:43pm
Brian Considine
An update ;
Reconnected the battery this morning -
Mirror power fold working & mirrors no longer "twitching".
F/N/S window operates from it's own switch.
Neither front windows operate from drivers switch.
Both rear windows operate from drivers switch.
Mirror adjustment now working. 2003 Range Rover Vogue TD6
Post #564797 17th Aug 2020 8:40am
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I sounds to me like the is a short somewhere, damaged wire shorting to ground, as it effects mirrors and windows I would be thinking door loom, check the door connector from the body to the door in the hinge bit for any signs of damage.
Post #564800 17th Aug 2020 8:53am
