![]() | Home > Maintenance & Mods (L322) > Brake pad warning light. Cutting back wiring . |
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 ![]() ![]() ![]() |
No one..?😭 2003 4.4 Adriatic Blue FF |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 299 ![]() ![]() ![]() |
On my D3 if you cut the wires at the brake pad warning sensor and join the two ends together, it stops the pad sensor warning light. The pad wear sensors are cheap to replace.
Thanks Ivan.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2660 ![]() ![]() |
According to the L322 wiring diagrams in the Wiki, 2 wires connect to the instrument pack in connector C0234 at pins 4 (yellow) and 20 (yellow with brown stripe). The 2nd wire from each connector are linked to provide the path. Joining pins 4 and 20 would short the path to indicate that both pad wear sensors are intact. |
Good man..
