Home > In Car Electronics (L322) > Ground Loop issue - Finding Earth on IHU on a 2007 |
Djbonsu Member Since: 23 Sep 2019 Location: Chicago Posts: 14 |
I also had this same issue and used a ground loop isolator by Tru Connex (shown below) It worked great however I NEVER had issues before until the navtool and I believe their is something inside of the navtool interface that is causing this issue. Maybe try a different ground loop isolator that doesnt attenuate the signal as much. My unit defintly attentuated the signal but I plan to also add a ground loop isolator to the mic and a gain booster after the isolator for the aux signal. Personally I believe this is a navtool issue and that they should look into this and send out replacement units.
10th Aug 2020 2:05pm |
michaelpalmer7 Member Since: 08 May 2015 Location: Bedford Posts: 21 |
Thanks for the info.
10th Aug 2020 5:18pm |
Yea, I was wondering the same. I checked through all of the pages but couldnt find anything |
10th Aug 2020 6:22pm |
