Home > LPG > L322 Prins LPG Removal |
Super7 Member Since: 23 Feb 2019 Location: Somerset Posts: 19 |
the tank should have a non return valve fitted so once you bleed the lines from tank to vapouriser (obviously in fresh air away from source of ignition, drains etc) then you can remove the tank with the lpg contained, you'll need to be careful where and how you store the tank prior to disposing of it, there is a PRV that will vent if the gas expands too much in the tank so keep it out of this lovely sun we are having! |
9th Aug 2020 8:08am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 698 |
Unless you’re planning on fitting it to another car yourself it’s probably not worth your time to remove it. Anyone with the skills and gear to fit, calibrate and certify it isn’t likely to bother using secondhand bits. |
10th Aug 2020 3:51am |
