Home > Maintenance & Mods (L322) > ZF6HP26 Metal or Plastic Sump |
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 |
Your best to use a metal sump and seperate replaceable filter element for future servicing. There are a heap of oils manufacturer rated for ZF6HP available that work every bit as good as lifeguard 6 and cost 1/10th the price ... No idea what country your in?
5th Aug 2020 4:10am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1778 |
Metal sumps are notorious for leaking
5th Aug 2020 8:57am |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
Stick with the plastic version, cheap enough to change out again if you ever service the gearbox again. |
5th Aug 2020 12:39pm |
Sorry but if you have fitted a metal sump as used stock by bmw and ford on the same transmission and it is leaking you have done something wrong!
5th Aug 2020 2:21pm |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
I fitted a metal pan and separate filter 12 months ago. No issues at all. (I did use genuine Lifeguard 6)
5th Aug 2020 5:31pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 593 |
Appreciate all comments so far, but I make it 2 all, I was hoping for a more decisive response....
6th Aug 2020 12:54am |
I think whoever changed your fluid and not the filter / sump was a clown
9th Aug 2020 3:47pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
I changed to a Britpart supplied metal sump during a gearbox oil change. It has the advantage of cooling fins on the understand and, more importantly, the filter is separate. |
12th Aug 2020 1:26pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Is flush from cooler lines possible?
12th Aug 2020 4:07pm |
mickd Member Since: 26 Jul 2020 Location: Brisbane, Australia Posts: 5 |
I have switched to metal pan as well when I serviced the ZF6 on my TDV8. It came with different bolts as well due to different length used on the plastic pan. The thread holes needed cleaning out so that the new (shorter) bolts could be torqued up properly and evenly. They tended to thread in further than the original bolts used, so you can imagine some of the grit build up on the unused portion of thread which is exposed on the top of the box.
18th Aug 2020 8:27am |
Sorry for late response Mick, If your still curious i use Gull Western Syn Ts, Many guys are runnig this in 400rwkw turbo fords with same transmission, you can click on the data sheet and read they fully aprove it for ZF6HP
13th Feb 2021 11:04am |
Hey Dave,
14th Feb 2021 2:20am |
You've probably already seen you can get 20L of that oil for about $180... plenty for a flush.Repco currently have it on special in 4 liter botles for $37 , I cut the tube off the original plastic sump and with some hose and tubs make my own flushing device and let the transmission suck up and spit out about 4 liters to flush before re filling which helps clear the oil in the torque converter giving you a far better oil change.... sorry i might have mentioned this before, Anyway I've still got half the 20 liter drum left and about t do another change now that I've put about 80 thousand k's on it since
14th Feb 2021 6:18am |
Unfortunately I turfed the plastic pan when I fitted a steel pan. Sounds like a good way to flush the old lube out. I might be able to use part of the old filter that is in there now.
14th Feb 2021 8:59am |
