Home > Maintenance & Mods (L322) > 3 Button Key
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
Knightmare wrote:
Interesting, but I was under the impression that this type of upgrade to the flip-style couldn't be done for the 2007 models Sad
Or that's certainly the impression I'd got from the various posts on the forum? Happy to be proved wrong though Thumbs Up
I can assure they work perfectly on the 2003 though not sure on the 2007
NO modification or replacement of ANYTHING on the car is required either Thumbs Up 2009 - L322 5.0 S/C Autobiography
Post #501809 16th Jan 2019 5:21pm
is this what you lot are trying to do,
https://www.fullfatrr.com/forum/topic8500.html
[from our wiki]
Post #501810 16th Jan 2019 5:23pm
RS2000CUSTOM
I used a kit like this to convert mine
https://www.ebay.co.uk/itm/Range-Land-Rove...rk:24:pf:0 2009 - L322 5.0 S/C Autobiography
Post #501814 16th Jan 2019 6:35pm
Knightmare
England 2007 Range Rover Supercharged 4.2 SC V8 Barolo Black
Thanks RS2000CUSTOM and Stan, but unfortunately both of these don't allow for the 2007 key.
Pretty sure Daveo confirmed as much on a previous post. Frustrating as hell!
I have found these guys (https://www.themasterlocksmith.com/) in Palmers Green, London who say they can do it for £140 all in, if you go to them. Still cheaper than LR I guess, and at least you're there when they do it.
Will certainly try Timpsons though, just in case. Life is what happens while you�re making other plans.
Post #501815 16th Jan 2019 6:43pm
pcourtney
East London way is Marius - his mob is 07828 933622 postcode E17 5EE
he can do L322 keys prior to 2005 - but you have to unsrew the centre console and give him access to the EWS - he then does it while you wait
and he can do L322 keys post 2005 (which your car is) without you needing to give access to the EWS module
NB when L322's left the factory, the immobilser module could have up to four keys progammed ( but usually only 2 or 3 were ever provided when the car was new ) , so if you only have 1 working key, its a good idea to clear these lost keys (just in case someone might have an old key to your car)
Post #564036 9th Aug 2020 3:14pm
